-   -   Engine hard to start when cold (https://www.offshoreonly.com/forums/general-q/254268-engine-hard-start-when-cold.html)
87MagnumII 05-23-2011 09:00 PM
Just breaking in my new engine and it runs fine once warm but is very hard very hard to start. It's acting like it s flooding but can't figure out why. Here is the run down
350 with vortec heads, 650 demon w/mech secondary, lt4 cam, performer rpm manifold. Mallory marine 4110 electric fuel pump that is pre set to 7 psi.
I have the four corner screws turned out 1 1/4 turns. The floats seem to be letting fuel come about 3/4 up the site glasses. It spits and sputters but once it clears out it runs and idles fine. Once warm it starts pretty easy i just cant figure out whats up Any help would be appreciated as the first big weekend is coming up as we all know, lol.
rexcramer1 05-23-2011 09:04 PM
Does that carb have a choke plate on it?
87MagnumII 05-23-2011 09:15 PM
Yes it has electric choke
rexcramer1 05-23-2011 09:25 PM
Assuming the plate is closed all the way when the engine is cold, I would experiment with different starting procedures.
Are you pumping the throttle before you turn the key? Pumping the throttle while the key is turned?
87MagnumII 05-23-2011 09:29 PM
Plate is closed all the way when cold. After it starts it loads up when you try to rev it up a little. It takes about 30 seconds for it to clear up and blows out a bunch of smoke until it finally clears up. I'm afraid it's gonna wash out my new rings if I dontfigureit out
kubelwagonman 05-23-2011 10:06 PM
i set chokes on my holeys at wide open unless real cold,,,,pump it a few more times an idle up for warm up,....chokes a waste a time in texas!!!
87MagnumII 05-23-2011 10:13 PM
So you think it may be over choking itself?
Boat1 05-24-2011 08:03 AM
I would completely remove the choke plate, shaft, and related hardware. If the engine is correctly set-up it will start and run when cold, warm it up by running 1200 rpm for a minute or so and your good to go. I have seen the plate close when wave jumping re-entry happens, this dumps alot of fuel. Chokes on a boat are usually more trouble than they are worth. If you must retain it, adjust it so it has the minimum effect.
87MagnumII 05-27-2011 10:28 AM
we adjusted the choke open a little and lowered fuel level in bowls and all is good now, thanks for the help guys
