| Enforcer |
05-24-2011 11:23 PM |
Intercooler plumbing question
I have read tons of posts on here regarding intercooler plumbing, but I cant seem to find if anyone has tried this method..... First off... I have put together a fresh 500EFI w Vortech v4 Supercharger Kit. Per Vortech Instructions the intercooler is fed from the pressure side of the sea water pump after the fuel cooler but before the oil cooler. Water pumps through it fine with 10 an fittings and 5/8 hose and dump off the transom. Water pressures in upper 20's at 5000 rpm low 60s mph (small 25 pitch high slip prop for testing). At idle or on the hose.. I am getting tons of condensation in the intercooler, which gets pushed through the engine when rpms increase. (I dont like the idea of it ) So for testing purposes I put a valve on the intercooler exit line, at idle or on hose shut it off and condensation is eliminated. Turn valve full on for running. I purchased a Teague modified pressure relief valve and am wondering why I cant just put it down on the 1 1/4 inch fitting that feeds my intercooler, or on the exit line from the intercooler and set it to around 5 or 6 psi. That way as soon as I come off idle the pressure will open it up and continue to force it open more as pressure increases feeding the intercooler. What about FLOW? My total system pressure (measured from block fitting) may increase as I reprop and gain speed, if so then I can put another bypass in and dump overboard. At idle on hose or in lake is about 3 - 4 psi. I just want to easily eliminate the idle flow through the intercooler without adding a through hull or transom intercooler pickup. I am running a dual pickup XR drive, which seems to provide tons of water underway. Thanks for any input!
