engine alignment with offshore mounts
just got engine in and the rear of the engine is down about 1/8" or so...by looking thru gimbal bearing, has solid offshore mounts and just using the fibre washers at the bellhousing, can I shim with a washer or another fibre washer ? thanks Rob
do you have your stainles steel double wound spacer inside your fiber washer?
If not merc. part #13-33734
Originally Posted by KWright
(Post 3413266)
no, was told on this boat(98) you do not use them ??? but have no idea...they were not there when I pulled the engine...did not ck engine alignment when it came apart
When I pulled my engines mine also did not have the stainless steel double wound washers/spacers. I contacted merc and they stated that more than likely the engines had been out and the mechanic failed to install. My washers had been taped in place with electrical tape. Merc rep said that was fairly common to tape in place while installing engines. I reinstalled the spacers. I have read on offshore mounts adjustment is made at the front mount with your bolts(redrill holes slightly to get room to shim). I wouldn't do this, it's bound to slip eventually. If you're drive slides in and out of coupler it should be fine. If you haven't had couplers/u joints failing, I'd put it back the way it came out, but with the washers. Also look up alignment tool. I'm no expert, hobbyist boater, take my advice with a grain of salt! But this is what I did.
I just talked to a Merc tech said need to put the spring shim back in....I have a pair here, so will try to lift just the rear up enough to slid them in..hate to unbolt the front mounts...
| All times are GMT -5. The time now is 03:41 PM. |
