Help, trying to convert from crossovers to thermostats
http://www.hardin-marine.com/p-14350...-455-olds.aspx
Anybody ever convert from crossovers to thermostats using this kit? I was going to buy this kit, but I only have one water inlet hose that is currently hooked up to my crossover and this kit requires two. Do I need to run a T or something to convert my single water hose into two so this kit will work? If so, were do I put the T? Under the pully's?
What do ya'll think of this kit? Will it work? My engines are not getting near the heat that it needs. Water temp gauges don't even register 3/4 of the time. It says not designed for sandy areas. My lake has all natural sand beaches. I don't plan on running aground, but not sure how well the thermostat will hold up in my water. I dont' mind cleaning out the thermostat every once in a while.
Current setup
Current setup
I run a crossover with a stat before..worked great..looks like you would use the lower 2 to manifolds and just one of the upper ones as a by pass, plug the other...my housing just had the bypass right on the top....looked cleaned than this one...eddie marine and cp both have them
Beak botr
Looks to be unique type system and funky log type manifold with dual water inlets.
I know the OEM Merc system worked using a circulation pump and the new style thermo housing but it wasn't cheap. It does work, and work well. Had to get new circ pumps, pulleys, belts, and thermo housings. I always had problems getting oil hot with cross-over as I hardly ever push it past 3000 rpm also not run for more than about 15 min on plane ( I have to idle for 45 min to 1 hour just to get to location for planing speed, thank you F&the sea cows club). OEM system gets water and oil up to min temps while on the 45 Min idle out to mouth of bay. Once at speed I can get where I an going rather quickly.
Last edited by 88Fount33; 05-26-2011 at 02:54 PM. Reason: Manatees taste just like chicken, save a boater eat a manatee
