HELP. Backwashing 496 after impeller replacement.
Can I safely backwash from the port side water drain (at the Actuator Assembly) without forcing water backwards through the riser into the engine?
Did your impeller actually come apart while running? If not there is no reason to back flush.
impeller replacement and backflush
Originally Posted by soonenough
(Post 3415191)
Upon removal and disassembly of pump, there was absolutely no water in the raw sea water system (I had completely drain it last fall), and as far as I could tell, all (99%) of the impeller pieces were in the pump housing. I want to backflush just to be certain there are no blockages. |
| All times are GMT -5. The time now is 09:49 AM. |
