-   -   what should i tap into (https://www.offshoreonly.com/forums/general-q/254693-what-should-i-tap-into.html)
Fountain4402 05-30-2011 07:23 PM
I have a garmin hard wire cord on its way what should i tap into. I was thinking cigarette lighter
Duck Diggler 05-30-2011 07:31 PM
I always like to run a seperate circuit for everything. Not big into tapping off of other power sources escpecially for electronics. You have a fuse block you can come off of ? Not saying it cannot be done its just what I prefer.
US1 Fountain 05-30-2011 08:51 PM
Look under the dash. My Fountains have both had a fuse panel underneath
Fountain4402 05-31-2011 07:20 AM
i took a quick peak and didnt notice one Ill have to look harder. How do you tap into a fuse block, and im assuming there should be an empty fuse or an acc one.
Fountain4402 05-31-2011 07:21 AM
true and just an idea for now, but that little garmin pulls hardly any juice so I wouldnt see the big issue
sleev-les 05-31-2011 07:35 AM
I wired mine to the gauge circuit. Like fountain said, they dont pull much and the line also has another inline fuse in it (garmin cord).
LaVita 05-31-2011 10:40 AM
I just installed a gramin 441 in my Checkmate and ran it to the fuse block. It was located right behind the dash. Garmin says to use a 5 amp fuse.
US1 Fountain 05-31-2011 11:12 AM
It's not the fact that the Garmin has an inline fuse that you should believe it's ok. It's the size of the wire that you are tapping into. It already has a load on it. That said, the Garmin has a low draw and more than likely no problem.
Most accessary fuse blocks will have empty positions you could simple use for any/all additional circuts. Ideally put each circut on a separate fuse. The main power feed for the fuse block as a whole will(should) have a circut breaker to protect the fuse block as a whole.
Fountain4402 05-31-2011 04:01 PM
there is one fuse block underneath on the back wall. Its only like 4 fuses and tube design, one empty place, dont know if thats going to be a good idea
Duck Diggler 05-31-2011 08:06 PM
+1
