-   -   525 hesitation? (https://www.offshoreonly.com/forums/general-q/254810-525-hesitation.html)
bsboss 05-31-2011 08:30 PM
525 hesitation?
Still trying to figure why my boat is slow to respond. Push throttle from idle and it revs up to around 1500 rpm for about 4 seconds or so and then revs up and pulls hard. I check for fault codes and had 3 active, #75,#118,#191. My wot rpm is down too. Wondering if I could have intake leaking? Can't here it. This is my 2nd weekend with this boat, and trying to work out the gremlins. Any suggestions?
TWIN-SPINS 05-31-2011 10:50 PM
take a spray bottle of water and spray down the whole engine while its running,,,if there is a leak you will hear it ,,,when you get to the leak
bsboss 06-01-2011 08:52 AM
I will try that, old school we used starter fluid, but I guess that could be a little dangerous.
I was hoping someone else had experienced similiar issue's that could shed some light on this?
