-   -   Engine start up Issues (https://www.offshoreonly.com/forums/general-q/254932-engine-start-up-issues.html)
Fountain4402 06-02-2011 07:47 AM
Twin 454's and the engines run great. I wouldnt say it starts super hard but it doesnt start easy and I usually have to pump the throttle on each 4-5 times as well. Im looking for these things to start on first turn of the key or at least easier. I was thinking maybe some carb cleaner in them. It't not electrical I dont think. I have new batteries this year and they read fine, also have new slave solenoids.
jbraun2828 06-02-2011 07:59 AM
Could be fuel pumps leaking back fuel or carbs not holding fuel. Have carbs ever been rebuilt? kits are cheap.
Fountain4402 06-02-2011 08:04 AM
i dont know. It shouldnt have a fuel pump since its carbed right
gsxr1216 06-02-2011 08:08 AM
How do you think the fuel gets from the fuel tank to the carb then??
yes it has a fuel pump on it, but its mechanical VS an electric pump like a EFI boat would have.
dirty carb could be the issue?
Fountain4402 06-02-2011 09:31 AM
ok thats what I thought. It seems the carbs either arent holding fuel or are dirty. What part would you rebuild if they were holding fuel
firehawkcat 06-02-2011 08:57 PM
Are we talking hours between starts or days or weeks
BDiggity 06-02-2011 10:27 PM
My 525sc's sometimes take 8+ pumps when starting cold. Normally the rest of the day is fine, but the initial start is a challenge. my old 454 mpi was turn key & go.
Larry D 06-02-2011 11:21 PM
carbs tend to do that if you leave boat sit for a week or even a few days I think fuel evaporates out of bowls and depending on your carbs you may not have chokes ( mine are hp series no choke ) b ut as was said above once they start mine will start easily they rest of the weekend , so I am not sure you have a problem unless somthing has changed or you are having trouble after they are warmed up
SkiDoc 06-03-2011 04:34 AM
If they're losing fuel could be the needle seats. To check after shut down remove the air cleaner and look down the throttle bodies. You
will see fuel dripping if they are leaking. It is a common problem. When I had carbs I always kept a spare or two. Also may want to make sure your timing hasn't changed. I've seen that years ago in my ski boat.
Thunderstruck27 06-03-2011 07:23 AM
Do a total rebuild on both...
Fountain4402 06-03-2011 07:37 AM
Maybe a week or two between starts. And yes there is no chokes. I usually pump 2-3 times maybe I need to do it a a few more time and give it a little more throttle. Like I said once its running for the day its turn key every time. I also have the boat tilted when I store it, so maybe fuel is running out of them
tinman565 06-03-2011 07:46 AM
Think about this....back in the 60's and 70's...when carbs were common...you almost ALWAYS had to pump the accelerator peddle a couple times to get the car started. Its no different now. Mine do the same thing on initial start up. Chokes would help...but I wouldnt worry about it. My chokes are disconnected.
I'm not picking on you when I say this...but if you didnt know there was a fuel pump on the motor, then I would let someone who knows what they are doing re-build them if thats what you ened up doing. :drink:
MILD THUNDER 06-03-2011 07:50 AM
I have never seen a carb motor start after sitting for a WEEK or TWO without pumping the throttles. Its a carb, not electronic fuel injection. Your carbs are fine.
kvogt 06-03-2011 08:00 AM
If they are Weber or Qjet carbs - thats normal on cold starts.
jwp 06-03-2011 08:01 AM
Both engines started to do this at the same time?
No chokes, Sits a week or two, Needs a few pumps to start, Sounds normal...
Fountain4402 06-03-2011 08:32 AM
yeah both engines.
hey man I grew up with fuel injection. Little different ball game
tinman565 06-03-2011 08:45 AM
Hahaha...I understand sir. I grew up when you got in the car...pumped the gas a couple times...PULLED THE CHOKE OUT...then fired it up...and pushed the choke back in after it was warm...lol. We also only had AM radio...and after a few years, we stepped into the "big time", and got an 8-track player. In my opinion...the best years of my life were when the high beam switch was on the floor in the lower left corner, and the shifter was a "3 on the tree". God I miss them days. :drink:
Fountain4402 06-03-2011 08:55 AM
yeah plus if you never ask you dont learn either
gsxr1216 06-03-2011 09:48 AM
I tell you what, i thought the high beam swtich on the floor was GREAT! the first car i had that wasnt like that and had it on the column annoyed the hell out of me!!!!:ernaehrung004:
BDiggity 06-03-2011 09:58 AM
another thing i have learned is on the first start in weeks after giving it 10 or so pumps, i keep it at about half throttle when trying to turn it over & feather it as it finally cranks over. then bring it back down to idle quickly once it is running. its been quite the learning experience on what it needs.
Thunderstruck27 06-03-2011 12:43 PM
Don't forget the vapor locks! I had clothes pins, aluminum foil and who know what else hang'n on my 49 merc's gas line. LOL:hitit:
fountainfan42 06-03-2011 02:56 PM
Originally Posted by tinman565 (Post 3419630)
So, I stopped to talk to her, and she volunteered to show me her "goods" if I'd give her a ride. Nothing a little waxing cant fix. :drink:
OMG thank goodness you had room on your boat .
