Tach does not look right??
Before I start it, tach is already around 500 RMP.
Gaffrig gauge, with a tattle tale switch and reset. But the tattle tale does not work. Just bought the boat, so not sure how it should work (it looks simple and obvious, but you never know) Motor is a 500 HP carb. How can I check? I hate the idea of buying a new tach, and nothing wrong with the old one. Or maybe its that switch (not sure how that switch works) |
Dont worry about it. Mine read "whatever" till I start it...then they read perfect. Yours is fine. :drink:
Tattle tail is for the GPS Speedometer. Should show top speed until reset. Gauge may be at 500rpm. When engine fires it should read correctly. Good luck
Mine do the same also
Thanks Guys,
Ya, mine starts @ 500, so looks broken. Glad you have the same reading. It's a Gaffrid switch, with 3 postions. I think is says TACH, Recall & Erase. Won't be at the boat till the weekend, will double check what they show. |
Tach NOT working now
O.K. Now I know something is wonky. THis weekend, was all over the place, or did nothing at all....
Where should I start to look to see where the problem could be? THanks again! |
Originally Posted by 2Slow4me
(Post 3433623)
Tachs often don't go to zero with the key in the off position. They should go to zero with the key in the on position and engine not running.
Originally Posted by Griff
(Post 3434125)
New boat to me, so not 100% familar with the sound, but I think I'm bouncing off the rev limiter. Would like to try some props, but really need to get the tach in order before I start trying props. |
(Post 3435258)
Thanks Griff, I'll check if its doing that. It does not read, or only shows 2000, its not close to being accurate.
I lucked out, started with looking this weekend, for loose connections etc.
And it was the little nuts that hold it in place. They are missing, so the needle was touching the glass every now and then causing it not to move. |
Mine does it to guess i will see if mine is tight as well Thanks
| All times are GMT -5. The time now is 07:03 AM. |
