525EFI Have Knock Sensor?
Does the 525EFI have a knock sensors?
I would have thouhgt so but I don't see it on the lookup
I've seen on parts lookup on older, but didn't wee on later models? Where working with 08.
Anybody?
Originally Posted by bsboss
(Post 3423512)
Anybody?
Can I upgrade the map (send ECU's back to Merc?) and not use the knock sensor? I have a ghost in one motor and the knock sensor is one possible problem. Any other changes that might make the new map worth while?
Fixx
Originally Posted by EdNewman
(Post 3467081)
I can see the knock sensor but mine has no wire going to it. When I pull up the parts description my 2008 doesn't show to have.
knock sensor is not on, therefore it cannot cause an "issue" in the running of the 525's. In early models, the only code on was the knock sensor hi/low which means it was only checking to see if it was plugged in. It does not pull timing, it does not detect detonation, it does not add fuel for detonation.
| All times are GMT -5. The time now is 09:56 AM. |
