-   -   No spark from coil - low voltage across leads (https://www.offshoreonly.com/forums/general-q/255469-no-spark-coil-low-voltage-across-leads.html)
Budman II 06-08-2011 10:47 PM
I'm starting to wonder if I'm ever going to hear this damn engine run! First the exhaust alignment issue, broken head bolt, then the coupler issue, and now this! :mad:
I went to fire it tonight, but alas, no spark. Checked connections at the coil, verified that rotor and distributor cap looked OK (both are new), but still no dice. I ran a DVM across the leads on the coil, and it was only showing around 7 volts. Checked voltage at pin #5 on the main connector (purple wire), and was getting 12.7 V there. Disconnected leads on the coil, and if I put positive lead on the purple wire coming in from the harness, and then run the3 negative lead on the DVM back to the battery ground I get 12+ V. However, if I touch the wires attached to the ground side of the coil, voltage drops back to 7 V. It seemed that the voltage only was dropping when the coil was hooked up to the wires. It did the same thing when I ran a wire directly from the positive side of the coil to the pos side of the battery, and still no spark.
So I borrowed another coil - no change. Installed a different ignition module - no change. Checked and double checked all my ground connections on the back of the engine, but did not find anything loose.
The only component I have not replaced is the pickup coil in the distributor. Could this cause symptoms like this? Other than this, I guess I will have to go through the engine wiring harness piece by piece.
Looks like another lake trip without my boat! :mad: Damn I hate electrical problems!
dagah2x 06-09-2011 06:09 AM
Silly question but the rotor is spinning right? I dont think the pickup coils go bad very often.
1BIGJIM 06-09-2011 06:24 AM
Weak spark -
The sensor has nothing to do with it, just like the advance control module. They work or they don’t. Weak spark, first think check the battery. I worked on a boat last year with similar problems. Owner said it turned over fine but would not start. I put a volt meter on it and turned the engine over. It dropped in volts so low the spark was to weak to start the engine. Silly as this sounds I charged the battery for three hours and it started right up. Owner could not believe it, and what I charged him to charge a battery.:eek:
arandaz 06-09-2011 09:15 AM
I hear that. Just spend A LOT of money on my motor to find that I need a custom carb. Next weekend hopefully...
As I read on, I thought the same thing about the battery...sounds insulting but give it a shot if you haven't.
