500EFI Whipple idle problems >
Old 06-18-2011 | 09:12 AM
  #41
Originally Posted by skydog
Ok so I don't think its a vacuum problem if it was it would do it on start up and all the time.
well it idles fine with just the start of the key, and then when u give it some throttle and back out it wants to stall, when it starts to stall i can hear the iac open up and then it either sits and high idles or surges. like something is happing when it goes from negitive to positive vacuum
spyderconv1999 is offline
Old 06-18-2011 | 09:17 AM
  #42
im thinking the engine builder did not replace the o-rings between the intake and plenum, they were for some reason to big to put back in when we had it apart. soooo he said he had to order new ones from merc (not 100% sure he did)
Old 06-18-2011 | 09:19 AM
  #43
i swapped map sensors between motors and it gave me the same map sensor low code, that means manifold pressure was low right? like maybe a vac leak?
Old 06-18-2011 | 09:28 AM
  #44
Yes buddy man if u can get a smoke pro it will take all the guess work out. Or start motor and spray down to look for leak. Careful not to start a fire. Or go buy smoke pro then return it when done......haha sorry had to say it they are like 1000.00 man.
skydog is offline
Old 06-18-2011 | 09:37 AM
  #45
cool buddy thanks for all your help, i did talk to dustin at whipple a couple times, he said he has had very little luck with spraying and getting a difference in rpms on a 500 efi motor, but i did try it anyway and didnt find anything, im just going to go home after work today and pull the plenum off and check out the o-rings
Old 06-18-2011 | 09:43 AM
  #46
Cool best of luck. Just don't like the fact tps volts are hanging up that's not right. Keep pushing u will get it. Some times we look to deep and hard and the problem is right in front of face.
Well I am heading home now from hospital with a new baby girl talk soon!!!
Skydog
skydog is offline
Old 06-18-2011 | 09:46 AM
  #47
Ps how far from north ill are u? I got a smoke machine u can use.
skydog is offline
Old 06-18-2011 | 09:53 AM
  #48
WOW congrats, we just had a baby girl too, well 10 months ago...........damn time flys
Old 06-18-2011 | 09:59 AM
  #49
Congrats to u too buddy!! That's got to make boat problem that much funner I am sure.......
skydog is offline
Old 06-18-2011 | 11:36 AM
  #50
I'm still thinking vacuum if that makes you feel any better LOL. Don't rule anything out, could be your plenum o-rings, intake to heads, behind the throttle body, etc. It seems the motors trying to make up for unmetered air.
Jpzaluski is offline
