-   -   need hatch actuator (https://www.offshoreonly.com/forums/general-q/255627-need-hatch-actuator.html)
mreedy 06-11-2011 01:55 PM
need hatch actuator
Working on boat my hatch actuator quit working, luckly up. Does not make any sound so I checked for all power problems. none found. If they go out dont you generally hear something??
Main question is who is a good source for buying a new hatch actuator??
tinman565 06-11-2011 02:39 PM
Did you try running jumper wires right from the battery to the hatch wires ? Did you try taking the dash switch out of the equation ?
Here is one that was for sale a couple days ago. Maybe it will work if all else fails ? :drink:
http://www.offshoreonly.com/forums/s...-actuator.html
KEPP 06-11-2011 02:52 PM
We are give us a try............... http://www.keitheickert.com/c-40-ele...actuators.aspx
Sincerely
mreedy 06-11-2011 03:20 PM
I believe switch is ok with voltmeter. With red wire extending and yellow retracting I was not sure about jumping it. so you just saying yellow to (+) post and red to (-) post?
weather gets better tomorrow I can try that.
Thanks Kepp, If last option dont work I'll contact you monday..
