-   -   Help!!! (https://www.offshoreonly.com/forums/general-q/255650-help.html)
Someguy 06-11-2011 09:36 PM
Help!!!
i have a checkmate 251 that had a omc 460 then a volvo penta 415hp 502 efi that i just had rebuilt and put back in with a holley carb and thunderbolt ignition due to the ecu killing my motor. So heres my problem the throttle cable pushes instead of pulls on my carb linkage. do i need new contols? please help I want to go boating baddly with my new engine!!!!!!!!:evilb:
36Tango 06-11-2011 10:00 PM
Depending on your type of throttle, you can make the correction there. On my gaffrigs, there is a location for pushing, and one for pulling.
Mbam 06-12-2011 07:48 AM
If you can'd do it up at the dash on the throttle either flip your cable mount bracket at the carb around or get a different one. I have some red anodized ones if you need one.
