-   -   Trim tab starting height? (https://www.offshoreonly.com/forums/general-q/255951-trim-tab-starting-height.html)
miwettig 06-16-2011 11:28 AM
30' Power Quest. twin 496-mag HO's, Lenco 16" single actuator tabs. The manufacturer says to position the tab so that the trailing edge of the tab is 1" above the straight edge line drawn from the bottom of the boat. From the factory mine is about 3" I takes about half of the total extension to get to that 1" Is there a reason they are set that high? I can choose a different hole and lower them??
endeavour32 06-16-2011 11:59 AM
I've always been told 3/4" to and 1".. 3" seems way to high.
boatnt 06-16-2011 02:50 PM
I will look and take a picture of mine today..
miwettig 06-16-2011 03:14 PM
Thanks...mine is in the middle hole.
boatnt 06-18-2011 07:50 AM
1 Attachment(s)
Yep ,,,same as mine...maybe its time to move it one hole closer.
miwettig 06-18-2011 07:54 PM
I moved mine Sat. and noticed improvement. Before I had to go too half tab to see and benefit. Cut thru the chop better and when I needed to compensate for the wind it was just a touch!
