scarab 22 switch alpha to bravo any tips or thoughts
I have a 94 scarab 22 trying to swap outdrives from alpha to bravo. What would be the best way to go about it?
Find a good Bravo Transom and Outdrive - drill two more holes - bolt it up .... if your using the same engine you'll need to add an engine driven sea water pump as the Alpha is in the drive - Bravo is engine mounted...
Originally Posted by jason.w.maddox
(Post 3432351)
Originally Posted by Too Stroked
(Post 3432392)
This might be a silly question, but why swap? The Bravo will take more HP than an Alpha, but you're going to loose speed due to greater drag.
(Post 3432392)
(Post 3432413)
I'm trying to go from alpha to bravo. Does any body know what gear ratio i need? Also are the deminsion's the same beetween the alpha and bravo as far as the distrance between the prop and the boat and does that affect anything if it is different?
Originally Posted by A.O. Razor
(Post 3432446)
Before you continue with the question below, I suggest, you adress this question. Are you looking for advice, or just someone to confirm your own ideas?
Second. Yes. The X-dim on the Alpha and the Bravo are the same, more or less. I think there is 3/13" diff. You are asking about gear ratio??!! We don't even know what engine you are running, and what your current drive ratio with the Alpha is??? Current GPS speed @ ??? rpm and prop model/pitch. Are you looking to upgrade your power? If not, LEAVE WELL ENOUGH ALONE! If your are not running big power, the Alpha is a much faster drvie. I am currently running the 5.7l with 260hp would eventually upgrade with a new small block producing around 400hp. RPM's are about 5200 @ 55mph with a 21p prop. |
The alpha will hold up fine.Just don't air it out and return to water without letting out of it.JOHN SR
Originally Posted by Fenderjack
(Post 3432475)
If it blows , just put on one of those life time replaceemnet ones for 700.00
lifetime replacement?
