-   -   Algae in fuel tank (https://www.offshoreonly.com/forums/general-q/256124-algae-fuel-tank.html)
endeavour32 06-19-2011 06:52 PM
Algae in fuel tank
I've got some nasty build up of algae scale in my gas tank. My filters are plugged after 8 hours of run time. Any suggestion as to what I can dump in the tank to kill this stuff... I've been searching the web but all I can find is products for Diesel, nothing for Gas. Any suggestions.
firehawkcat 06-19-2011 08:40 PM
I have used Lucas quite a few times on cars and trucks always worked great dont know what it would do in your situation with the algea. Might check their web sight you never know or call them im sure they have a R&D tech maybe pick their brains good luck sounds like a real mess
jeffswav 06-19-2011 08:47 PM
Are you sure its not a pure gas then e10 issue? I find it hard to beileive alge would live in a fuel environment.
endeavour32 06-19-2011 09:00 PM
What I'm dealing with is a dark flake scale that varies in size from a grain of sand to a 1/4" and about the thickness of a sheet of paper. When it dries its a light green color. I really don't know what it is other than its causing me all sorts of grief and I've had about enough. I just assumed it was algae any suggestions as to what else it could be and how to deal with it.
jeffswav 06-19-2011 09:06 PM
That sucks, I'm not the expert on this but I find it hard to beleive its a growth. This may take some time to work out.
Budman II 06-20-2011 09:50 AM
It sounds like some type of scale or corrosion from inside the fuel tank. I am assuming you have an aluminum fuel tank in the boat, right? If the boat was left sitting for a long time outside without a full tank, it is possible that a lot of moisture built up on the inside walls of the tank. You may have to pull the sender and get a look at the inside of the tank to determine what is going on. I know that copper oxidizes to a blue/green color, but I always thought aluminum oxidizes white. I have also read that the ethanol in today's fuel is causing some fiberglass tanks to break down, but this usually results in a jelly-like substance in the filters and strainers.
Good luck.
nards444 06-20-2011 09:56 AM
To me it sounds like water, you either have rust in the tank or corrosion or if you have algae its because of excess water or moisture in there. I doubt there is a algae that can live in pur gasoline environ ment
jeffswav 06-20-2011 10:10 AM
I have heard of people having trouble with the switch to e10 fuel. With pure gas a sludge can build up in the tank, when the ethanol is introduced in the tank it cleans out the sludge. You may just have to keep changing filters untill it clears out. Good luck with the problem...
gsxr1216 06-20-2011 11:04 AM
you can absolutely get algea, fungi, and other bacterias growing in fuel. typically its more common in diesel fuel but it can occur in gasoline also. i have a diesel truck and run additive in very tank to prevent stuff like that from growing in it.
this stuff would do what you want but is damn expensive?? you may be able to find it in smaller quanties somehow?? i'm not sure how you would easily get all the crap out of your tank though after you kill it all?
http://www.microbikill.com/microbikill.html
ezstriper 06-20-2011 11:08 AM
never heard of it in gas...diesel for sure....sounds like alcohol fuel that broke down from sitting...seen plenty of that !!!!
endeavour32 06-20-2011 09:19 PM
The boat sat for 8 years and the tank was 3/4 full of old crappy gas. I pulled most of it out and have been running it and trying to track down various issues but it seems that everything I've been look for is related to the build up in the tank. I've put about 10 hours of run time on this and have gone through 2 sets of filters. Things seem to be getting better and filters are lasting longer. The first time I pulled the fuel filters they were showing signs of rust with in a week. Now there is no rust just lots of scale. The fuel tanks are aluminum with copper pick up tubes. i guess all I can do is just keep running it and suck the scale out...
DMOORE 06-21-2011 11:07 PM
STARTRON. This stuff is amazing. I use it in all engines/ vehicles if they sit. It's also great for periodic system cleaning. It works on all types of engines and fuels, and is designed to clean algae. It actually has live enzymes that clean the system.
Darrell.
endeavour32 06-22-2011 06:15 PM
Darrell.
Thanks for the info! I'll pick some up.....
