If he spins that motor 6000rpm and has 100% effiency.. it would be about 87mph. So the numbers are off.. I say it is the speed number that is bogus..
Friend of mine had an h2x, went 109mph at Lake of the Ozarks, several years ago. Set a record, not sure if it still stands. At that time he had 1170hp. |
I had my 2001 H2X 6.2 (320 hp) running 58mph GPS 21 p/prop @5100rpm, after I instaled the procharger 7lb boost went to 77.5 mph GPS @5150rpm 26 p/prop, engine last for almost 10 hours. Now running 60mph GPS don't remember the rpm on a 377 blue scorpion.
Upper 60's with a 23p prop. 85 mph is impossible with that setup
My buddy has a 05 h2x with the 496 mag and a 26 bravo and the best he runs is 68.
65mph boat
I do believe that boat, and many others are all capable of 85 mph....off a cliff!
Originally Posted by dagah2x
(Post 3437128)
502 boat should get to 70 real speed. I though the 496ho boats were around 72? Mine ran real well, fast 21 degree hull but not so good in the 3 footers.
So the real answer to the question "Will a Baja H2X really go 85 MPH if dropped out of a plane" is yes. This is why speed changes you - I guess.
Originally Posted by A.O. Razor
(Post 3438352)
72??? No way, never. 67-68 tops for a REAL number without the sun in you back and the wind in your azz BS. I don't think 70 will be possible with the 502 either.
Funny, I was having a friendly arguement last night with a guy.
08 h2x 496 non ho. Swears 72 , told him 62-64. Told him the fountain would win. Bench racing and beer what fun! |
| All times are GMT -5. The time now is 05:51 PM. |
