Prop size mirages
What is the next size up from a 23 plus mirage
I can only seem to find 25 plus. is there a 25? |
Originally Posted by pantera232
(Post 3438121)
I can only seem to find 25 plus. is there a 25? http://cgi.ebay.com/ebaymotors/QUICK...item19c2baafe6 The one in this link is left hand. Just saying there is a Mirage 25. You would probably want a Mirage Plus 25. How many RPM are you turning the 23 Mirage Plus? |
Adam,
You said you were turning 5000 with the 23 you got from me, are you trying to turn more, or less rpm? Going up in pitch side(from 23 to 25) will lower your rpm. |
Trying to get more speed with a 25 but yes lowering the rpm, i figure if i can run a 25 at 4800 rpm ill be fine
I am turning a labbed 23 mirage 4950 rpm now, i have a 23 plus stock in the mail, just fig ill test them all and then sell what doesn't work ...
Rule of thumb one inch of pitch changes RPM by 200. If you go from 23 to 25 you will probably only be able to turn 4600 RPM.
Originally Posted by picklenjim
(Post 3438662)
(Post 3438532)
Just making sure you are going the right direction. |
| All times are GMT -5. The time now is 10:48 AM. |
