starter fuse link
I just replaced my alltinater on my 525 and now I have no power anywhere. I check power at the starter and I have 12v but after the fuse link on the starter I have none. Did the bad starter blow the 90 amp fuse link?
I ment to say bad altinator.
Alternator. Sounds like it may have. That would be the first thing I would replace.
Those also go out from corrosion and heat on the inside. I replace mine every couple of years and an alternator fried one as well. The are a pain in the azz. Not something you can easily go around in a pinch.
| All times are GMT -5. The time now is 05:26 AM. |
