Originally Posted by GPM
(Post 3442739)
Just wondering if they were burnt and if the water holes lined up between manifold and riser.
I am impressed
Out here in the sticks I dont come across these kind of boats. But you guys really know your ****! I am impressed and I am not being a smart ass. Just a complement.:}
Got the stainless exhaust tubing working. Water pressure was 22-25 psi while running so I'm good. Water temps ranged from 110 at idle to 180 while under way. Oil temp was 180-190. I had what I hope is a fluke when the oil temp spiked to 350*rapidly and sounded the alarm. Turned engine off immediately and then turned the key back on and it climbed from zero to only 190*. Do new senders cost much?
New senders are cheap. Probably under $50 depending on your gauge MFG.
How did your pressure go from 40psi with bad impellors, to 22-25 with new impellors?
Originally Posted by US1 Fountain
(Post 3445629)
pitts1313,
If you really want to keep an eye on what is going on with your water flow, as pressure can easily be inaccurate as a kinked hose or restricted heat ex-changer would give you a false understanding of what is happening. Check out this NEW product Livorsi is offering!! http://www.livorsi.com/pdf/water_flow_system_flyer.pdf |
Originally Posted by bbcmi
(Post 3446536)
pitts1313,
| All times are GMT -5. The time now is 10:03 AM. |
