-   -   Had boat fixed, want to verify (https://www.offshoreonly.com/forums/general-q/256666-had-boat-fixed-want-verify.html)
soldier4402 06-27-2011 07:18 AM
Engine is a 454 drive is a bravo 1. Had water coming in the boat from the drive. Looked like it might be the steering pin and the water seemed to be bubbling in from the upper part of the transom bracket. Took it in and they tore into it. All bellows were good, but the intakes hose was shot, had holes and was partially collapsed. He checked the steering pin and says it was fine. Could it have been this water intake hose.
Also if I want to do the jrmarine fix for the steering pin, does the drive have to come off for me to make this fix
US1 Fountain 06-27-2011 08:18 AM
Yes. Taking the drive off is the easiest part.
soldier4402 06-27-2011 09:38 AM
i just hoped the new hoses fixed it
US1 Fountain 06-27-2011 02:42 PM
Which intake hose was bad? the inside one or outside? A bad outside hose won't cause water to leak in the boat, you just won't get water to the motor. A bad inside hose will allow for both a leak and low water to the motor
soldier4402 06-28-2011 07:08 AM
inside
