-   -   What are these? (https://www.offshoreonly.com/forums/general-q/256790-what-these.html)
Baja_342 06-28-2011 09:53 AM
What are these?
1 Attachment(s)
Down by the drain plug? Guessing high speed water pickups for a genset????
JasonSmith 06-28-2011 09:57 AM
I'm guessing they are supply lines for the engines. The only way to know is to see where the lines run to inside.
I had them on my 29 for the intercooler supply lines.
CigDaze 06-28-2011 09:58 AM
Yep. Water Pickups. Though a genset wouldn't need two of them. Most likely they're for the engines.
Baja_342 06-28-2011 10:09 AM
Some kind of aftermarket extra water supply to the engines in addition to the drive pickups?
My genset's pickup is in the bottom of the hull. Thought it may be so gen can be run at speed.
fireboatpilot 06-28-2011 05:16 PM
Engine water pick ups for sure. My drive pick ups are capped off. I could never get enough water thru them to keep the engines cool. +1 on why would a gen set need 2 pick ups. My guess is their plumbed into the strainer in ports?
