the pickup tube presses in the bottom of the fitting, seen them plastic and aluminum..some have a small filter on the end..that could be the issure right there...
Originally Posted by ezstriper
(Post 3444893)
Originally Posted by hondahp4
(Post 3445009)
if i unscrew the 90* fitting from the tank, will the pickup tube come out with it? if not, how do i get it out? will i have to take the sending unit out or something in order to get to the tube?
if you take the fitting out and tube does not come out you have found the problem...but would not run at all...
ok guys, this boat is going to be the death of me......pulled the boat out this weekend (i know, June and my boat hasn't been dewinterized yet....shame) and have the exact same problem i had last year....again, no fuel pressure!!! this time while cranking my fuel pressure gauge says 5psi. as soon as the engine starts, it drops to 0.5 at idle and 0 at anything off idle. did the exact same troubleshooting as last year including putting the pickup in a gas can to rule out that again. if i pull the carb feed line off and crank it seems to be pumping fine and filled a 20oz bottle in around 6 pumps, but must be losing pressure once the carb starts feeding off it. i was thinking the fuel pump again (maybe the diaphragm has a pinhole), but there is no fuel coming out of the bleed line that goes to the carb. i'm yet again stumped by this fuel system....
Try checking for leaks in your fuel lines between the tank and the pump.
Originally Posted by drozz30
(Post 3701611)
the fuel pump is less than a year old, so i wouldn't think it would be bad, but its the thing i'm aiming at right now. i warrantied the old one the other day, so i'm waiting on a new one to come in later this week to rule it out. |
| All times are GMT -5. The time now is 08:59 PM. |
