-   -   power steering fluid or ATF in stock Merc PS? (https://www.offshoreonly.com/forums/general-q/257546-power-steering-fluid-atf-stock-merc-ps.html)
Budman II 07-08-2011 06:03 PM
Quick question - should I use a specific type of power steering fluid in a stock Merc PS system, or is ATF OK? If ATF, what type - Type F, Dextron, Mercon, etc.?
Thanks!
jeffswav 07-08-2011 06:43 PM
I have always used trans fluid
Budman II 07-08-2011 07:48 PM
Type F, Mercon, Dextron? Doesn't matter?
Thanks.
Smitty 07-08-2011 09:15 PM
Use the Dexron/Mercon blend and you will be fine.
jeffswav 07-08-2011 10:23 PM
Its all universal now
Rookie 07-09-2011 01:09 PM
Thanks!
Why not just use power steering fluid? I had ATF in mine when the line blew a pin hole leak in it and I had Red ATF everywhere. It made a mess. That Red dye is a mother to clean. A quart of PS fluid at Autozone is the same price.
45SS 07-09-2011 05:48 PM
I just put valvoline synthetic P/S fluid in mine and it has never worked so good, and as the other guy said, this stuff is clear. You can see the mess
gsxr1216 07-09-2011 07:59 PM
Thanks!
my book for my 1990 says dexron or dexronII thats what i put back in and all seems good:drink:
fireguy 07-09-2011 10:20 PM
Ya, and a quart of power steering fluid at the marina when you are out on the lake and it is 100 degrees and your boat dont want to steer is $12.00:eek:
