-   -   Hatch Lift Switch (https://www.offshoreonly.com/forums/general-q/257760-hatch-lift-switch.html)
srl520 07-11-2011 07:17 PM
Hatch Lift Switch
I replaced my 3 position lift switch couple months ago be cause the old one fell apart. I was always having to help lift the hatch and the switch would time out.
After replacing the switch, the hatch would raise very well by itself. Now it is back to me helping it again.
I was told that I needed to install a relay.
Anybody have more info on this?
What kind of relay and how/where to install?
Wally 07-11-2011 08:06 PM
1 Attachment(s)
Here's something i made up a few years back. Its a negative trigger so if you get any shorts in the line between your dash and the relays it wont blow or fry anything. If you want to keep your switch as a positive trigger then instead of post 86 on the relay getting a 12v+ wire it would get a negative ground connection.... :D
srl520 07-11-2011 09:54 PM
Wally thanks,
What does this relay look like?
Rookie 07-11-2011 10:26 PM
It's 2 basic relays together. You can get them at any auto store.
http://www.tristatetuners.com/forum/...ad.php?t=11349
teaguecustommarine 07-13-2011 06:26 PM
We have a hatch relay in stock that will cure your switch problem. It works by being the middle man between the switch, batteries, and the hatch lift. What could be happening is you are running to much power through your switches and it is killing them. With the relay, the switch will just turn the relay on. The hatch actuator will be basically ran from the batteries.
Give us a call and we can help it make more sense for you.
Hatch relay $55.00 and are in stock!
Eric
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
srl520 07-13-2011 08:41 PM
Thanks Eric
I will give you a call
Budman II 07-12-2012 03:55 PM
Yes, I know, I'm just digging up all of the old posts today. :)
Wally describes the option of going with a negative trigger via the dash switch. If I wire it this way, can I still use the existing DPDT switch in the dash? Is it simply a matter of disconnecting the power (+) lead going into that switch?
