Sea Water pump hoses..
So got both hoses off the pump, and cant remember what hose goes on the top and what one on the bottom..I think the top inlet on the pump goes to the drive..and the bottom goes to the oil cooler..??
Alot of of older pumps have a small plug on one side, look at the pump and see if there is this plug that could be plumbed to take a hose for a pressurre gauge or something. The side that has the plug is the discharge side.
My motors are 1998's, and the top hose is the inlet ( from drive) and bottom is discharge (to cooler). Just like a radiator.
Darrell. |
If your pump has the bracket in which the pump can be rotated in then it could be either. Mine has the bottom hose going to the pick up. You can disconnect the hose going to the drive and stick the end in a bucket of water and start it. Should empty the bucket real quick.
Just look at the impeller from the back through the hose holes. Assuming you put a new impeller in while turning the correct direction, look in each hole, and the one where the impeller blades are opening up from being compressed is the intake. The hole where the blades are being compressed is the out to motor hole.
| All times are GMT -5. The time now is 04:20 PM. |
