Originally Posted by jeffswav
(Post 3458102)
Get the exhaust with long risers.
Your compresion will be lower than 9 to 1, more like 8.7 to 1. I have 8.9 to 1 and I have 489 with flat tops and 110cc chambers. A crane 731 would be good, or get a custom roller from RMbuilder. You may want to use 2.19 valves, you will want to do a good job on bowl blending with bigger valves. Here are the head specs 336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports If you are going to run the 2.25 valves on a 4.25 bore, it woudl be a good idea to bore notch the top of the cylinders to unshroud the valves. |
I put in the forged domed pistons from speedpro :) over 9:1 compression
Still farting in the wind put a blower on it. Go with rm builder youll be pissn in the wind :) |
Originally Posted by pantera232
(Post 3458807)
Still farting in the wind put a blower on it. Go with rm builder youll be pissn in the wind :) Bob really knows what he is doing on engine/cam design. |
(Post 3458807)
It all worked out, but it took a real long time, between hard to get in contact with, long shipping, and him ruling out reversion and blaming my new head gasket and intake manifold gaskets, basically doing a top end job on a rebuilt motor after asking if reversion was a possibility.
I went with him bc i read so much about him knowing marine cams to avoid reversion. |
(Post 3459021)
| All times are GMT -5. The time now is 10:04 AM. |
