MAG MPI intake manifold options? >
Old 07-21-2011, 01:06 PM
Default MAG MPI intake manifold options?
2001 454 MAG MPI, lower manifold corroded. Options I've come up with so far:
replace with carb (requires a bunch of ignition parts swaps?)
replace with OEM part(s) from OSO/Ebay
replace with 500EFI setup (anybody done this swap? Parts interchange?)
replace with Holley EFI setup
Perhaps weld up the lower manifold if it's not too far gone. But being a salt water engine I put it far down the list.
A cam and maybe headwork are on tap for upgrades but nothing radical. Aftermarket exhaust that is Silent Choice compatible might be on the list also. Primary goal is to be running again as quick as possible.
handfulz28 is offline
Old 07-21-2011, 02:43 PM
Received 1,821 Likes on 907 Posts
Get a used freshwater setup off ebay or from the classifieds or swap shop.
Old 07-21-2011, 04:24 PM
piece of cake. mine did the same thing. go to the welder, have it tigged up for 100 bucks or less, go to the machine shop and have it faced for 100 bucks or less and you are done.
stevesxm is offline
Old 07-21-2011, 06:55 PM
z,
Just fixed one a month or so ago. If it is just badly corroded right at the inlet to the water passage, then it is a piece of cake to weld it up and resurface it. One key to doing the job right is to get a die grinder with an aluminum bit and grind away every bit of corrosion before you weld it back up. Any performance machine shop that does cylinder head porting should be able to fix it for you. Figure in the $250 range.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 07-21-2011, 08:48 PM
Thanks guys. Still hesitant to weld on a salt water piece though. Keeping eyes open for a replacement while deciding on a shop. Gotta do some searching for MPI mods.
Old 07-22-2011, 06:26 AM
is it the same as the 502 upper and lower? ive got an upper and lower off a 1999 502 mpi sitting in the garage i havent got around to listing for sale yet. PM me in interested.
dagah2x is offline
Old 07-24-2011, 09:19 PM
ballon78's Avatar
arnt they all brass lined??? everyone i have seen is???
ballon78 is offline
