-   -   454 mpi overheating or not???????????????? (https://www.offshoreonly.com/forums/general-q/259172-454-mpi-overheating-not.html)
busto 07-29-2011 08:56 PM
what is too hot for a 454mpi engine. running 170-180 wide open, port engine running 160. New impeller, back flushed system. AM I being paranoid or is it ok
firehawkcat 07-29-2011 09:06 PM
I would say you are ok as long as it is running good would not want to go much higher
firehawkcat 07-29-2011 09:07 PM
warm lake water might have a lot to do with it also
busto 07-29-2011 09:22 PM
before the impeller went out both engines always ran same temp at wot. I did replace impeller housing also.
jeffswav 07-29-2011 09:45 PM
Did the impeller come apart? If so did you recover all the pieces? They could be in the oil cooler, that would block the flow.
snapmorgan 07-29-2011 10:08 PM
Mine always ran 175 with a 160 t-stat
Griff 08-02-2011 11:12 PM
The temps are not bad, but you might want to try a new T stat.
My 502mpi's run about 165 at cruise and 175 running hard.
