Goto 540 or Tweek out the 489
#31
Anyone have experience with this cam?
https://www.cpperformance.com/p-1675...-camshaft.aspx
Why is that? Curious....
Thanks. Brad.
(937)545-8991
#32
articfriends (05-06-2022)
Rookie (05-05-2022)
#34
Not saying it wouldn't work, I just don't believe it would be the best choice if buying a new cam. If it was sitting on the shelf I would definitely throw it in.
Switched out a straight split cam with one that has a 6° split and it was much healthier and better performing. These heads were optimized and have great exhaust ports. JMO
#35
https://www.flotekheads.com/store/Bi...2cc-p130160438
#37
More round table talk….
Another note: if you are truly at 10.3:1, the cam you have is too short in duration. The cam you have was trying to achieve more cylinder pressure , which you don’t need nor want now.
Note#2: You where reving 5500rpm. My guess is that was just passed max power. 224 is a tow truck cam for near 500cid.
Somewhere 236-240 at .050” intake duration is where your motor will want to eat. Prob 240
You have an exhaust to handle it?
#38
-Tightening lobe centers (lsa) does also.
-Amt of Exhaust open degrees past TDC on intake stroke is what really means the most when it comes to reversion possibilities since the exhaust valve still open (but closing) when piston going down drawing in air from both valves (intake valve starts opening before tdc intake stroke) at lower rpms.
Look for some of my cam charts comparing the mag 454/502MPI/ HP500/Crane 731/500EFI/525EFI/Crane 741 and you’ll see seat overlap, .050” overlap (including btdc and atdc), etc, etc. Really good info that if studied, paints great pictures. :thumbs
