-   -   Weird issue (https://www.offshoreonly.com/forums/general-q/259431-weird-issue.html)
Ntrsspray 08-02-2011 07:01 PM
Weird issue
first off here is my set up...twin 360cu in small blocks with blowers and dual 750s, mechanical fuel pumps, and a complete MSD ignition from boxes to distributors....Now on sunday ran the boat all damn day, started and stopped about 2 dozen times and then it got dark and pulled the boat, it was late soo the flushing would take place in the am...Monday morning I hook up the hose and off i go..so i think turn the water to port motor and hit the key...cranks and cranks give some throttle and nothing...has fuel pressure. i am pretty pissed off but deep breathe and switch to starboard motor and dont you jknow does the same god damn thing...i assume its spark but now i need to go to work......fast foward to 7pm monday for giggles i but the boat on the hose and VROOOOM both motors instantly fire and sound fine. i scratched my head and called my dad he said maybe the MSD is acting stupid, i said gee thanks pop good advice. again fast foward to today figured why not 10:30am hose on boat and both crank but no run.
A little more. Both motors have isolated batteries and electronics
PLEASE HELP
Payton 08-02-2011 08:07 PM
is the boat sitting outside? Could it moisture from dew?
Ntrsspray 08-02-2011 09:09 PM
Yes it is outside. Stays covered 98% of the time and the last three days have been almost identical in weather as well. I'm really confused and out of ideas. Have changed coils. MSD boxes. I am at a loss
ezstriper 08-03-2011 06:06 AM
well seems pretty weird that both would suffer ignition failures at the same time and come back at the same time...do you have a safety lanyard ??? if so I would change that...one of the only things that would take out both..
Ntrsspray 08-03-2011 08:18 AM
Each motor has a lanyard
Ntrsspray 08-03-2011 05:31 PM
Any more ideas. I really need help
fireboatpilot 08-03-2011 06:15 PM
Maybe some kind of grounding issue? Seems weird that both motors fail at the same time due to an obvious elec. issue?
Ntrsspray 08-04-2011 08:11 AM
Even though each motor is totally separate ?
4bus 08-04-2011 08:44 AM
They should share a common ground, most have a ground strap linking the engines.
Did you confirm that you have no spark? Have you pulled the dist caps?
Had a friend that could not start his boat in the morning, but it would start later in the day. Pulled the cap and there was green corrosion on all points. I changed the cap and rotor no problems since. My thought was the corrision combined with the moisture that had not burned off from the night before caused the issue.
fireboatpilot 08-04-2011 09:35 AM
DSo they both share one fuel tank? Possibly something fouling the fuel pickup?
Ntrsspray 08-04-2011 11:11 AM
The motors are a year old. I mean it is possible I guess corrosion and I'm not sure about the ground sharing but yes they share a fuel tank but I have normal fuel pressure
4bus 08-04-2011 11:47 AM
Check and clean the caps, what could it hurt? I clean mine twice a year and always find some corrosion.
Do you have marine or auto distributors?
Also you never answered- Did yoiu confirm no spark when the engines would not run? Fuel spark and compression, it is all you need. And i doubt you have an intermitten compression problem.
Next time it does it check for power to the purple wire on the coil, power to msd, and actual spark with a noid light on cyl one. If you have ignition it has to be a fuel issue.
Also make sure the power to the MSD is not coming from the same wire as the coil. In high KV ignition situations such as cold wet starts the coil and MSD combined will overload the power wire and cause voltage drop. Don't ask how I know :)
Ntrsspray 08-04-2011 04:14 PM
Sorry. Yes it's a no spark issue. Now that purple wire you speak of I have not checked yet. Work was busy. First thing tomorrow I will rip into it
They are auto distributors
Thanks for the help
