502 water pump which hose?
external water pump. Just change impeller and forgot which hose goes to which side. the pump cover has RH out on one side and LH out on the other. I assume that it means if its a RH drive then the RH out goes to the oil cooler? Problem is the hoses dont seem to want to go that way naturaly from the way it was hooked up? Any help quickly is appreciated.
LH and RH refer to engine rotation. You're LH rotation... So, the side marked "LH out" goes to your cooler.
Originally Posted by cubicinches
(Post 3469406)
Thanks everyone. Got it!!!
| All times are GMT -5. The time now is 12:05 AM. |
