need some marine blower cam help. engine builders inside
i am currently in the process of refreshing the twin sbc in my 28ft cigarette, i have a static cr of 8.25:1 dart iron eagle heads 180cc intakes on a 4inch bore stock 3.48 stroke, running stainless marine exhaust, blowers are weiand 142 plan on running about 8lbs, looking for a hydraulic cam that will be suitable for the blowers but still sound good at idle, the motors used to be 10:1 na motors with solid roller setups with a heathy cams and dont really want to loose the sound at idle :)
i have an idea around what specs id use its just i come from the automotive world and i know the marine world it way different. thanks for any help |
Originally Posted by b18cls1
(Post 3475972)
i have an idea around what specs id use its just i come from the automotive world and i know the marine world it way different. thanks for any help sound at idle... now THERE'S a critical and defining technical spec to chose a camshaft with... i know it's an alien concept but how about talking to RM builder and get the RIGHT cam for the mechanical combination and the sound is what it happens to be... |
Thats why i asked for engine builders input. Ill deal with whatever sound i get just wold like to keep the lope. I mean i can cut a cam on a lsl lobe or a xer lobe and have the same power band but one lobe is going to chop a little more. Or whether i cut it on a 115 lsa or a 113 will change the sound. I want the best cam for what i have and ill deal with it
| All times are GMT -5. The time now is 09:43 AM. |
