Originally Posted by 272bajadriver
(Post 3477140)
So is there a chance it hurt the ecm? I guess I'm just trying to double check, somebody else told me no but I wanted to get on here and ask just to be sure?
is this some sort of big motor with big fuel demands ? like 6 or 700 hp ? i can't see how a conventional hi press pump that can service 500 hp can be more than 300 bucks... the bosch ones were only a couple hundred ... but maybe i'm just way out of touch. wouldn't be the first time... |
Originally Posted by stevesxm
(Post 3477167)
well... the odds are , not... but as soon as you fix the wire and try it you will know. if it starts then you are ok... if not, look for tripped breakers and bad fuses before you slit your wrist.
is this some sort of big motor with big fuel demands ? like 6 or 700 hp ? i can't see how a conventional hi press pump that can service 500 hp can be more than 300 bucks... the bosch ones were only a couple hundred ... but maybe i'm just way out of touch. wouldn't be the first time... Here is the stock fuel pump # from BAM marine 808505T01 PUMP KIT-FUEL $670.17 $590.69 $0.00 $0.00 1.38 Lbs No Picture |
Originally Posted by rchevelle71
(Post 3477204)
It is a 250 Merc EFI outboard, fits in the VST tank, there are probably crossovers to aftermarket, but I couldnt tell ya what the # is.. I agree that it SHOULD not have hurt the ECU's, but ya never know if it fedback thru ground. However, if it did, I happen to have a used set on the shelf for that motor:drink:
Here is the stock fuel pump # from BAM marine 808505T01 PUMP KIT-FUEL $670.17 $590.69 $0.00 $0.00 1.38 Lbs No Picture when i got my motors they had the std cool fuel deal and neither pump would run. all i did was clean them and corrosion x them and marvel mystery oil/fuel mix them and then let them run unloaded for a while just recirculating gas/oil mix until they ran with that nice steady state 9000 rpm hum... and they are still running 5 years later... |
Do you guys know what size gauge wire that is?
Hard to tell from the pic, but judging from what I see next to your Batt cable I would say 10 - 12 guage. I can look at mine tonight or tomorrow, and tell ya for sure. Or you could take the one off the other motor down to the store and match it up.
10ga
make new wire and add a 30 amp or so circut breaker in line, just use a std auto 2 post....that might help find the issue and not be a bad idea anyway ?
Originally Posted by chewyjr18
(Post 3477331)
10ga
Fixx
two things came to mind when i saw the wire was...When a wire is loose at a connection it will usually burn the end of the wire from it arcing out and heating up and melting...also if the main positive cable is loose or defective it will use the smaller wire as the main big positive cable and melt the wire in the process..
(Post 3477140)
So is there a chance it hurt the ecm? I guess I'm just trying to double check, somebody else told me no but I wanted to get on here and ask just to be sure? Also what size gauge wire is that so I know what size to get on the new one?
The fuel pump should run off a relay so the ECM should not have been damaged. I would also say 10 gauge wire at most. Assuming the fuel pump is toast you may be able to remove it from the VST housing and take it to a "good" auto parts store and they may be able to match it. |
| All times are GMT -5. The time now is 03:53 PM. |
