-   -   ECM question (https://www.offshoreonly.com/forums/general-q/26026-ecm-question.html)
mxz800 06-06-2002 06:33 PM
ECM question
i was hoping to find out if an ECM off of a 1996 7.4 efi mag would work on a 1999 7.4 efi mag . thanx Rob
SpeedGirl 06-06-2002 09:15 PM
I checked the Merc Book...
1996 is a MEFI 2 case with MEFI 1 software..
1999 is a MEFI 3 case..
The pins are in different locations...
So I am saying NO...
obnoxus 06-07-2002 08:52 AM
Speed girl is right,,, they are different Gen motors,,, wont work.
mxz800 06-07-2002 08:49 PM
thanx Rob
SpeedGirl 06-07-2002 10:58 PM
Thanks Rob!!!!!!!!!
What am I chopped Liver...
I knew the answer he just aggreed with me....!!!!!!!!
:confused:
obnoxus 06-07-2002 10:59 PM
And who the heck is Rob !!!???:confused: :confused: :confused:
cobra marty 06-08-2002 07:31 AM
OK smarty pants, so whats the difference between the MEFI 1, 2, and 3. What years for each. Advantages and disanvantages.
SpeedGirl 06-08-2002 08:13 AM
First: The cases are different...
Second: Pin placement are the same on 1 and 2 but different on 3...
MEFI 1 has 9 fault codes
MEFI 2 has 16 fault codes
MEFI 3 has 23 fault codes
MEFI 1 is 1993 GM software
MEFI 2 is 1996 GM software Merc didn't use till 1997
MEFI 3 is 1999 GM software...
Pros and Cons: All three systems work on speed density. The more fault codes the easier to diagnose a problem.
Any other questions..
:p :p
mxz800 06-08-2002 06:41 PM
thank you speedgirl your knowledge is unmistakingly amazing:D :D :D by the way i am Rob guess i didnt use the proper technique so everyone would understand
thanks, Rob ( < thats my name:p )
obnoxus 06-09-2002 09:13 PM
see what trouble leaving that little comma out will cause ya !!! Nice to meet you Rob !!!
Dennis
