Anyone have MSD 6M connectors off bad unit?
I need some electrical connections for a MSD 6M2 box. Over 4th of July one engine would not go so I blamed it on the MSD box when it was the ignition module. I found a 6 AL at the Autozone, cut the connectors off the what I think now was a good 6M and did a neat job of wiring the 6M connectors into the 6AL. Anyway I was hoping some one might have some connnectors off a bad unit they could send me. I know there are plenty in land fills. Thanks, Eric
they are just WeatherPak connectors. you should be able to get them new at any good auto parts store. you can get the wire ends and use your original plastic plugs or get both if you tossed your plugs. they do require a specific type of crimper for the wire ends.
PM with your address and needs. Weatherpak series is easy, but what cavity count? And, do you need the male or female? Remember, connector gender is determined by the terminal gender. Do not look at the physical look of the connector to determine gender!!! I do not wish to assume what your needs are.
Thanks for the replies, found 1 in about 45 minutes. Thanks again!
Eric,
If you need anymore, let me know. Im sure i have a few laying around. |
| All times are GMT -5. The time now is 09:58 PM. |
