EFI Codes
I have an EFI starting and running problem.
S/N OK005833 454 MPI MEFI 1 Trouble code 42 ignition control and code 33 MAP Here is what I've done so far, I cleared the codes and replaced the Distributor and the map sensor,the codes reappear without starting the engine, had both parts on the shelf and the other engine the ECM stays powered up with the key off but it kills the engine and all of the gauges are off when you turn the key off. Anyone have any ideas? |
ttt
fixx
ck ignition switch,make sure the power stays on with the ignition on,,also check all grounds..
Thank you Mr. Fix, I swapped ECM's and the problem stayed with the ECM,can those be repaired?
| All times are GMT -5. The time now is 02:51 AM. |
