Knock sensor
I just blew a motor melted piston
I did see the k knock sensor wire off Would this retard my timing and cause damage |
The knock sensor retards the timing when it senses detonation. If the knock sensor is disconnected the engine can be destroyed from an ignition system that is too far advanced (thus detonation).
Generally the knock sensor protects the engine from poor gas, a severely overloaded boat/overpropped boat or extremely hot weather. |
My wire fell off I was looking around motor and saw
Wire off |
Mefi?
Originally Posted by Dennis Moore
(Post 3490402)
Generally the knock sensor protects the engine from poor gas, a severely overloaded boat/overpropped boat or extremely hot weather. Thanks. |
A boat that is over propped will not reach the recommended WOT range. It causes the engine to work much harder. It like going up a small hill in an empty truck vs going up a steep hill towing 10k.
The engine works harder and cylinder temps increase which increase the risk of detonation. |
Mefi #1
| All times are GMT -5. The time now is 03:32 PM. |
