Swollen hose 3.0 OMC Cobra
I have a 1996 Four Winns with a 3.0 OMC Cobra. When the engine is revved up the U-shaped hose between the engine water pump and the thermostat housing swells up. I recently blew one of these hoses that was not very old. Any ideas???? I have disconnected the exhaust manifold, changed the thermostat, and checked the water pump. Now I am stumped.
Any help or ideas would be appreciated. Thanks |
Is a restriction somewhere. Typically a clogged manifold and/or riser is root cause.
Is it salt water boat? How old is the manifold and riser? |
This is a freshwater boat. I disconnected the hose to the manifold and it did the same thing
Check your thermostat gasket , sounds like u put the wrong one on , the square end should be straight threw so water can go to your manifolds, if it isn't cut it out and use some permatex
| All times are GMT -5. The time now is 06:53 AM. |
