trim not working
trim not working
had both of my ecus reprogramed on my twin engine 496 boat...now I can not trim up with the trim button on the throttles or with the 2 trim buttons on the dash,,could trim down .....only way I could trim up is with the trailer button..any ideas??? some one told me I might have to reset the settings in the ecus with a lap top...
thanks
thanks
Do U have smart craft gauges its program thru that if you do ?
Also you have 2 solenoids mounted to your trim pump bracket next to the trim pump itself - one solenoild is a down and the other one is up - make sure your connections are good plus no corrision issues there. It could be the solenoid itself is bad. Also check your trim limit switch back mounted on the side of the gimbal ring - this could be way out of adjustment or bad - Good luck
What do you have? Guessing Bravo. . If it's working with the trailer switch than the solenoid is fine. Trim limit switch. Take apart and clean the contacts and it will work fine.
