TRS Trim Anchor Pin Help
I am trying to remove the tie bar saddles on my TRS drive because I am going to full hydraulic steering and using the tie bar up high. I can't seem to get the trim ram anchor pins out to save my live. Any ideas?
Thanks |
I assume you soaked them in WD-40. They can be a problem if they haven't been removed in a while. I usually bang them out using a brass drift. Put a nut on the threads do you don't mess them up.
1 Attachment(s)
These?? Maybe put some penetrant (PB Blaster) on them and let them soak over night.
Those would be the ones. I have been letting them soak. I will keep at it.
Thanks |
I have also double nutted them and spun them to loosen them and spin them out. Also wood and a hammer, do not hit the threads.
Damnnnn, Look'n good there Rookie!!
| All times are GMT -5. The time now is 01:43 PM. |
