MEFI 4.. How much HP??
Looking thru Tuner pro at the "flag" settings I did find were you can enable it for peak and hold injectors but did not find a setting for low impedance , I looked thru "hex" editor at raw bin numbers and couldn't find anything close to what you described, not sure the software I'm using will do it though, Smitty
CNC,
I offer this simply as added information, but I purchased new injectors from RC engineering to replace the 24lb KEIHIN 5JAB KN-1 24 lb/hr injectors Merc used on my motor with 42 lb RC units. I was able to go to their shop in Torrance with my intake manifold, rails, plenum and ensure their injectors physically fit. They were more than accommodating and their injectors work great so far. No leaks or any other issues.
I thought I remembered 100+ lb high impedance units but I couldn't find them on their website. It may be worth a call or try the low impedance peak/hold style.
They run $649.95 a set of 8. They are a modified Bosch injector and are the short, stubby version, they require aluminum spacers to make standard length (included with inj). They have minitimer connectors.
