Power Valves
Power Valves
Need help..
i have a 4150 holly carb, and today i went to check the power valve to see what size it was..
this is what i saw, just wondering if this sounds correct because i've search summit i didn't see this size....
i also had my 10yr old daughter double check the #'s to make sure..lol
4 @ the 9 o'clock postion
E @ the 12 o'clock position
2 @ the 3 o'clock postion
thanks in advance
Q
thanks in advance
Q
Don't understand why it has those numbers and letters but this vides shows how it should be.
http://youtu.be/6vKlAnKdcB4
We need more info on your setup. Carb size ? Carb number ? Motor details ? I personally have never seen numbers like that..and I'll bet that you'll just end up with a standard 6.5 power valve. But please give us all the info.
