-   -   Procharger / intercooler winterizing question (https://www.offshoreonly.com/forums/general-q/263403-procharger-intercooler-winterizing-question.html)
tylogan11 10-03-2011 09:38 AM
I have a general question for the procharger guys: after you run antifreeze thru your motors do you drain or keep the antifreeze in your intercoolers? I want to make sure I winterize my intercooler the correct way don't want any surprises in the spring.
tbanzer 10-03-2011 12:22 PM
I drain my intercooler first then run anti freeze thru it and leave it in there till spring. Hoping for some corrosion protection.
Mr Gadgets 12-05-2011 04:48 PM
What kind of antifreeze is recommended for this? Are some RV antifreezes better than others for the intercooler?
ezstriper 12-06-2011 05:59 AM
none of the RV anti freeze have any corrosion protection...I use reg anti freeze, run on hose before putting in water..so all flushed out..
