Change to synthetic oil?
Hey guys,
As you know the boat is a '93 check convincor 251 with a carbed Mercruiser 502ci and a bravo 1. I was wondering if I can/should switch the motor over to synthetic oil. I was talking to the local parts guy at the marine shop and he said not to switch to synthetic since the motor is old. The motor was rebuilt about 110 hrs ago, I just wanted to get a second opinion from you guys. Thanks again, Seth |
you can switch to syn with no issues.....need to keep the weight up to 15/40 or 20/50
Which one of those would you recommend? Glad to hear I can switch over, I thought that parts guy seemed a little odd....
Seth |
I would recommend the 20w50.
I use 20w50 amsoil
I like Royal purple....
I just switched to Amsoil Dominator 15W-50and amsoil Ea076 oil filters(the big dogs hold 2 quarts of oil alone) and just switched to Amsoil synthetic marine gear lube.
I switched my '94 7.4 over two years ago, at 196 hours. Running M1 15W50, no issues at all.
Do you guys normally buy oil and fluids online or just go to the local marine shop? Any good online websites that sell for a discount?
Thanks, Seth |
From what I understand about synthetic, is that it not only holds up better, but it swells your seals more than regular oil. That is why you can't go back to regular oil once you switch to synthetic. I would think switching an older motor to synthetic would be ideal.
^^^You can go back to regular oil anytime, aint gonna hurt a thing.
Originally Posted by ICDEDPPL
(Post 3522522)
Ken |
| All times are GMT -5. The time now is 07:11 PM. |
