-   -   Bow lift through use of skeguard??????? (https://www.offshoreonly.com/forums/general-q/263782-bow-lift-through-use-skeguard.html)
Flying Tomato 10-09-2011 08:42 PM
Ok, here is my thought, and I am curious if anyone has tried this. I aquired a skeguard on a boat that I immediately took off because I did not like the look. However, I have noticed that this particular model has a triangular "foil" (wing)on the bottom of it. The foil is not very big, maybe 1 inch across at the rear.
I'm wondering if installing this skeguard would ultimately give me some bow lift due to the bottom wing. (Shouldn't it pull the drive down, thus lifting the bow?) Also, what if the wing was a little bigger??
Surely someone has done the testing. Thanks in advance as I am sure I will get some response on this one.
Flying Tomato FT
SFOcean 10-10-2011 02:14 AM
I will be testing this same thing on Wednesday; will post on Thursday. Never mind why I needed a Skeg Guard in the first place :drink:
GTOFFSHORE 10-11-2011 07:18 PM
It would need to be alot bigger and then it would be like those plastic ones you see at Wally world. On a slow boat they can be a cheap way of helping with planing etc. Things that are done through prop tuning on hp boats.
SFOcean 10-13-2011 12:31 AM
"I will be testing this same thing on Wednesday; will post on Thursday"
The little plate on the bottom of the Skeguard does enhance the trim just a bit, both down and up. My Avanti is extremely trim sensitive, so the effect will not be much on most boats. I am glad I took the time to get the skeg on so the lower plate is exactly parallel to the propshaft. I also faired the skeguard in with epoxy to the drive's nose cone and case. Having a full sized skeg sure helps with the low speed handling and it very nearly eliminated the deceleration-induced boat torque while coming off plane (this is why I tried the skeguard repair, my other drive with a good skeg has no bad traits). The boat may have lost one MPH, overall I am happy.
Flying Tomato 10-13-2011 01:39 PM
more bow lift??
Well, I put the skeguard back on yesterday and went for a ride.
The boat feels like it has more bow lift. It is not a huge difference but I believe it helps!! The boat definately gets light now and I replicated my best speed ever of 83.3 gps. Without the skeguard I could never get the bow up and top speed was 79-80.
SFOcean 10-13-2011 07:00 PM
Cool; seems like that little bit of bow lift is all your boat needed. :ernaehrung004:
Now that you know you like it, you might want to fair it in to the drive; this should cut down on drag and clean up the flow to the prop.
