-   -   454 Mag EFI oil cooler upgrade (https://www.offshoreonly.com/forums/general-q/264038-454-mag-efi-oil-cooler-upgrade.html)
snapmorgan 10-13-2011 10:18 PM
I have replaced my 454 mag with a 540 and would like to upgrade my oil cooler. I have looked at coolers for hours now trying to find something that will work. My mag setup has a PS cooler mounted to top of bellhousing, cool fuel on port side of engine and the oil cooler is mounted vertically in front of engine. What do I buy and where do I mount it. I could remove the PS cooler and put on a combo cooler on the rear of engine, but it can only be about 16" long. If I use a stringer mount on port side, I will have to do away with the cool fuel and replace fuel system. I find nothing that will work in the stock location. Can't go with bigger diameter because it will not fit behind the tensioner bracket. I could mount one on the starboard side and run the lines under the oil pan, but I know that I need to keep the lines as short as possible.
I am sure that this has been done many times, but I can't find a good solution. Any ideas? Pictures? Part #s
articfriends 10-14-2011 02:03 AM
1 Attachment(s)
I mounted mine on stringer as shown in the pic, ditch every factory fitting from filter adapter to block adapter as they are sized for requirements of your stock motor, not a 540 with more hp and probably bigger bearing clearances. I too had to move my original cool fuel set-up but I ditched that too and went with bigger stuff, Smitty
snapmorgan 10-14-2011 08:16 AM
I read your old post about upgrading oil systems and coolers and found it very informative. I am going to replace everything, I just don't find a good place to mount the cooler to work with my existing water line routing and my cool fuel works fine on the 540 so I hate to spend a grand to take it off just to have a place to mount the oil cooler. There are thousands of these MAG motors out there that have been or will be hopped up. It shouldn't be this difficult.
snapmorgan 10-18-2011 11:37 AM
Is there any issue with putting an oil cooler on the suction side of the raw water pump? I have plenty of room there and can loop the oil lines under the oil pan and keep them fairly short.
apollard 10-18-2011 02:18 PM
I wouldn't put it on the suction side - putting restriction (as an oil cooler will be) on the suction side of the pump creates a much higher loss of flow than on the pressure side. You may end up reducing flow, or causing loss of prime.
snapmorgan 10-18-2011 03:33 PM
thanks
