-   -   A/F Devices Monitoring Devices (https://www.offshoreonly.com/forums/general-q/264143-f-devices-monitoring-devices.html)
Rockfish71 10-19-2011 05:24 PM
Originally Posted by hallj (Post 3528975)
I would hope for a little more counter bore on the sensor installation to get it into the exhaust stream.
http://www.offshoreonly.com/forums/g...tallation.html
Jeff
The Innovate Motorsports type of sensor measures at the tip only so you don't need to install deep into the exhaust system this style runs cooler and last a longer as long as it stays dry. It's is just a bosch o2 sensor.
Trash 10-20-2011 06:44 AM
Originally Posted by 87MagnumII (Post 3530722)
Does a sensor need to be installed on each exhaust manifold or just on one side to get a reading? Also, how thick is that adapter plate and is it a pain to get your exhaust lined back up with the tips and y pipe for silent choice? If running A sensor on each side do you need two gauges or can you run them to one gauge for an accurate reading?
You only need one side, but you can do both sides and double the cost of equipment required.
The adapter plate is about 1" thick.
It can be a pain to get the exhaust aligned back up. Straight hose out the back with a little flex will work without too much difficulty. If you have silent choice that would complicate things.
You need one gauge per wide band sensor.
Griswald 10-20-2011 02:12 PM
I believe Innovate makes a gauge that will support two sensors
James 10-20-2011 02:25 PM
FAST fuelairspark.com has a dual O2 digital for $ 450.00 and for $ 150.00 more you can get the rpm adapter that will overlay rpm's to a laptop. But you do not need a laptop to use the digital unit
flying J 10-22-2011 04:23 AM
Would one of these monitors be good for tuning on a carb engine? Checking plugs is kinda a pain and I just wondered if this would be a solution?
Griswald 10-22-2011 06:17 AM
absolutely
ezstriper 10-22-2011 08:37 AM
yes, going to use to fine tune my carb procharger setup..
