Outboard motor ??
I have a 1976 35 hp Johnson outboard with pull start. So there is no electric at all on the motor. Is there anyway to hook up a tach?
Anthony |
Check over here. You will probably get more replies.
http://forums.iboats.com/forumdisplay.php?f=24 |
Back in the day, lots of people would install these on their 2 cycle snowmobiles, lawnmowers, etc,etc. Can get as just a tach or hourmeter and tach.
http://www.tinytach.com/tinytach/gasoline.php |
Are you SURE your motor doesn't have a charging stator? Even a pullstart motor of that vintage might still have one.
Outboard tachs usually run off of the 12-pole charging stator. I did have an old 33hp Evinrude that had an external generator for charging. I tapped into the coil trigger, and set a car tach to "4 cyl" mode. It would read 50% of what the motor was turning. (each cylinder of a 2 stroke motor fires every rev - a 4 stroke 4 cylinder fires twice each rev). TinyTach works okay, but I've had several of the cheap ones go bad pretty quickly. |
No charging coil at all. Just two black wire leave motor and they go to the cut off switch. So Im assuming no charging capailities cause I thought the same thing. This is a 2 cylinder 2 stroke motor. Do they make a tach with a pick up wire that can be wrapped around a plug wire, like a timing light pick up?
Anthony |
Originally Posted by nordic95
(Post 3532723)
But HEY, I just found this: http://www.cartpartsplus.com/tachometer-dial-type.html It'll work. MC |
| All times are GMT -5. The time now is 03:25 PM. |
